Results 1 to 7 of 7
Thread: flashing yellow lights.
    Nov 2007
    Default flashing yellow lights.
    I was updating the firmware and then two yellow light started flashing on the v2. What does this mean and is there a way to fix it?
    2006 Trailblazer SS
    Twin Turbo 67 Chevy Truck
    SOLD Truck 2002 Chevy kb turbo t70 5.7l
    The alternating flashing yellow LEDs means you just flashed in the bootblock, and V2 is now in dead poll mode, i.e. V2 is waiting for the firmware to be flashed in;
    i.e.you now have to flash in the firmware.
    When you're done, your firmware should be at version 2.07.22 (from V8 build 170), please verify this.
    Nov 2007
    Ever time plug into the laptop the two yellow lite start flashing. So you are saying need to flash the bootloader again?
    2006 Trailblazer SS
    Nov 2007
    Can you please write in more detail on what needs to be done. Thanks
    2006 Trailblazer SS
    Open V8 Scan & Tune with your V2 plugged in. Double click the V2 icon in the windows taskbar by the clock, then click the F6 Firmware tab. Click Update BootBlock first if it says there is a newer BootBlock available, then once the yellow lights start flashing again click Update Firmware. Should reboot and be back to normal. Go ahead and exit this window. Now format the config section and recopy all of the config files over. Use EFILive Explorer with the V2 connected, click F9 Config, then click Format Config. Exit EFILive Explorer and return to V8 Scan & Tune. In V8 S&T click F5 BBX, then make your selections and click Program. Should be ready to go now and be fully updated.
    With flashing yellow lights, click Update Firmware as Erik said.
    Note that bootblock and firmware are not the same thing.
    Nov 2007
    Thanks guys I got work again.
    2006 Trailblazer SS
  1. Removing yellow MAF wire required?
    By Gregs in forum E37, E38 & E67 PFI ECM's
    Last Post: March 29th, 2011, 03:11 PM
  2. Please Help Two yellow flashing lights
    By mike8890 in forum FlashScan V2
    Last Post: February 27th, 2011, 08:06 AM
  3. V1 Problems!!! No Lights... :(
    By CoryF in forum FlashScan V1
    Last Post: October 9th, 2008, 08:04 PM
  4. Flashscan lights dim ?
    By Boost in forum FlashScan V2
    Last Post: March 14th, 2008, 08:54 AM
  5. Help...ABS lights won't go away.
    By 1000HP in forum Gen III V8 Specific
    Last Post: December 4th, 2007, 12:44 PM
