I've noticed since I've upgraded to V7.3, I can't scroll over a particular portion of a graph like I could in earlier versions and read the data. Am I doing something wrong or was that feature deleted?
Seems to work for me...
Try pressing F2 (lock/unlock chart inspector vertical line) and see if this helps.
Cheers
Joe
Thanks, I had the keyboard only inspect checked. Duhhh!Originally Posted by joecar
Thanks Joe!!! I didn't know that trick. It just seemed to work every now and then. I just though Paul was messing with me
Andrew
EFILive Crew
Here I was thinking that my EFILive software was broken....... you learn something new everydayOriginally Posted by joecar
Chassis by Holden
Engine by Chev
PCM modified by Flashscan
Cam by Comp Cams
