Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 60
Thread: First time calc.vet attempt, I have issues
  1. #11
    Jun 2009
    If you get a chance can you take a look at the MAF map? It might just be bad information but when I do a paste-multiply into the MAF table of the tune, it drops the curve to nearly a straight line instead of a slope from low to high.
    I will try to do a better log tomorrow.
    71 Chevelle, LS1/4l60e, EPS 230/238 113+2, hand ported 799s, ported Fast 90/90, Doug's headers, 3.42 12 bolt
  2. #12
    For the MAF table:
    - did you create the map axis's by doing Paste Labels from B5001...?
    - are you using SELBEN as the map data...?
    - are you using MAFFREQ on the row axis...?
    (you can use any logged pid as the column axis)
    Post a pic of your MAF map.
  3. #13
    Jun 2009
    I will double check all of those parameters again. If it's still incorrect I will try building the map again and closing and restarting the program. If it still doesn't seem correct I will post a picture.
    Do I need to take any special considerations since I installed 41# Bosch injectors from a supercharged 3.8? I already used information from this forum to recalibrate the injector flow rate table and my part throttle/cruise must be close because the wideband gets stoic and the ltft are -5% to 0% at cruise.
    WOT, the wideband reads fat at 11.5 on the initial hit and from there it goes to low 11s by ~6000rpm.
  4. #14
    Jun 2009
    Well checked everything and tried it again, this time it looks like a curve so I guess it was a fluke or I did something wrong pasting/multiplying last night.
  5. #15
    Thunder, post a screenshot of the MAF map so I can see what you saw.
  6. #16
    Jun 2009
    I didn't change any settings, just made sure the filters were applied and re-pasted with multiplication.
    I think either I had forgot to apply the filter or it wasn't multiplying when I was pasting. I'm getting the hang of things a little more.
  7. #17
    Ok, that looks correct (all values are in the vicinity of 1.00).
  8. #18
    To make the MAF map narrower, in the map properties goto the Cells tab and checkmark Constrain Cell Size.
  9. #19
    Jun 2009
    Did a long drive with a lot more driving conditions. Seemed to go pretty well. The new map has a couple small spikes and I smoothed them some but I'm through for the day.
    Here's the tune file that resulted:
    Well I can't get it to upload, keeps saying "error #2038". Tried saving a copy as a different name and it won't upload either
  10. #20
    Try uploading tomorrow.
  1. E40 calc.vet??
    By rpmauto in forum Gen III V8 Specific
    Last Post: April 10th, 2012, 06:34 AM
  2. Calc vet ???
    By Chuck L. in forum Gen III V8 Specific
    Last Post: September 8th, 2011, 01:12 PM
  3. Calc VET
    By pormgb in forum Gen III V8 Specific
    Last Post: August 28th, 2011, 09:39 AM
  4. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 01:20 PM
  5. question about CALC.VET
    By acric5 in forum Gen III V8 Specific
    Last Post: July 6th, 2011, 07:56 AM
