Results 1 to 1 of 1
Thread: Using HPT to get EFI injector data???
    Senior Member Behold's Avatar
    Apr 2010
    Default Using HPT to get EFI injector data???
    It seems HPT has many more of the FORD releated fields in there system for helping use injector data. Could using HPT to upload to the PCM then use EFI to extract get the converted data I need???
    Just a thought....
    Added option If I set the IFR using the Spreadsheet on here or the ford data as I think that might be more acurate can I use the below to sort out the PW Table?
    GM.IBPW does include all offset adders & can be "proven" quite easily.
    Calculate the amount of fuel that needs to be injected by logging your airmass DMA pid. (Using the DMA pids tells you what the PCM is basing its calculations on.) Divide this by the commanded AFR to give you the fuelmass that needs to be injected. Then divide this by your IFR to give you the pulsewidth in seconds needed to supply that amount of fuel. Multiply by 1000 to give you milliseconds. I call this CALC.IPW & use this to base a lot of calculations on.
    You will see quite clearly that GM.IBPW & CALC.IPW do not match by a reasonable difference.(CALC.IPW will be significantly smaller than GM.IBPW)
    In areas where SPA, default pw etc is not used you will see the difference tracks very close to your volt/manvac offset.
    Still working on the SPA contribution but it certainly appears to be based on the CALC.IPW pid not GM.IBPW.
    Basically record a run and calculate the mass against Comanded AFR and replas the figures from CALC.IPW in to the table? surely then its just the volt/manvac offset that would need a tweeking for idle?
    Or am i really not getting this right now???!!!!
    Thanks Antony
    Holden Commodore GTS - LS1 5.7
    12 rib Crank Driven Vortech V2 Centri Charger (Intercooled) 9 PSI.
    LS6 Intake
    LS6 Heads
    YT 1.7 Roller Rockers
    BTR Dual Spring with Ti retainers
    BTR Hardend 7.400 Push rods
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    PCM LS1B with 512KB Running COS5 v01290005
  1. Replies: 42
    Last Post: June 16th, 2015, 08:30 AM
  2. 96# injector data?
    By BLK02WS6 in forum Gen III V8 Specific
    Last Post: July 2nd, 2011, 07:28 AM
  3. Converting a HPT to an EFI Live file?
    By Phantom Z in forum Lounge
    Last Post: April 7th, 2011, 07:27 AM
  4. can anyone convert ant hpt file into efi?help,help
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: December 19th, 2009, 08:10 AM
  5. main differences from hpt to efi live
    By boostedyards86 in forum Gen IV V8 Specific
    Last Post: September 11th, 2009, 08:42 AM
