Results 1 to 6 of 6
Thread: 00 to 02 OS full flash issues
    Aug 2007
    Default 00 to 02 OS full flash issues
    I swapped a 4l80e in my 2000 gmc 1500. I am trying to full flash in an 02 os that I choose because it has the same os as the 4l80 tune I segment swapped and want to eventually go custom os. Problem is the full flash is grayed out and not an option, only cal only tune and read pcm are lit in color and can be pressed. Any help???
    00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
    Aug 2007
    Here are the current and the tune I am trying to full flash in.
    kbpulled1120.tun
    KBSWITCHEDto02OSfinallywithexpress4l80esegswap.tun
    May 2010
    All you have to do is just hook up the flash scan to the car, have everything plugged in, then open the tune tool last.It should no longer be grayed out.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    Aug 2007
    Updated to latest version and solved the issue. Now on to fix the battery light coming on with new operating system ...
    Aug 2010
    Hello Slowrc,
    1999 truck OS did not use the Generator (alternator) "F" terminal (field duty cycle) - 2002 truck OS did. You can either set DTC P1638 to "Not Reported", or run a wire from PCM connector C2 (Red) pin 52 to the alternator "F" terminal (some schematics may call this the "I" terminal).
    Regards,
    Taz
    Aug 2007
    Thanks Taz! It runs, but like BUTT!!! Air fuel is all over the place, shifts to hard at light throttle. No full thottle drives for obvious reasons. Good gracious at all the work I have. As per normal all good advice is appreciated! !!
  1. KR after Full Flash new OS...
    By 01Blackerado in forum Gen III V8 Specific
    Last Post: March 18th, 2011, 07:06 AM
  2. Why cant I full flash?
    Last Post: March 17th, 2011, 10:11 PM
  3. Pre Full Flash to Full Flash Tune Question
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 12:43 PM
  4. Full Flash
    By L31Sleeper in forum Vortec V6/V8 Specific
    Last Post: November 26th, 2009, 10:25 PM
  5. HELP cant full flash
    By Madspeed in forum Duramax LLY
    Last Post: April 23rd, 2007, 07:05 PM
