Results 1 to 4 of 4
Thread: No Licenses on a NEW V2
    Aug 2006
    Default No Licenses on a NEW V2
    I purchased a new V2 several months ago. I haven't used it yet. I went to flash my PCM the other day and it shows no licenses used or available. Then I remembered that i didn't register the V2 yet. I noticed that the date on the License Manager which is the same date as my blue registration card is not the date that is in the V2 licensing box. I am not able to change the date of the V2 license to that of the registration license. Any suggestions as to what I am doing wrong. Here are two screen shots of what I am talking about.
    Jeff
Name:	V2 Licensing.png
ID:	12260   Click image for larger version.
Name:	License Manager.png
    Aug 2010
    Hello Jeff,
    From your screen shots, the licence date of the new V2 is May of 2010 ... is that correct, or should it read 2011 ?
    Also, ensure that the V2 is programmed with the latest Bootblock and Firmware, and after that program the V2 controllers and PIDs.
    Regards,
    Taz
    Aug 2006
    Thank You Taz,
    I just updated and now I am good.
    Jeff
    Perfect, and that's old firmware! There was an issue with a V7.5/V2 fw mismatch causing no licenses to be shown even though there were unused ones available.
  1. will I need to buy licenses
    By crash85 in forum Duramax LB7
    Last Post: November 1st, 2011, 01:43 PM
  2. no licenses available???
    By mstordahl in forum Duramax LLY
    Last Post: August 22nd, 2011, 12:15 PM
  3. All My Licenses disappeared!!! Please Help
    By BlackGMC in forum FlashScan V2
    Last Post: June 4th, 2011, 06:07 AM
  4. No Licenses on new V2
    By GPI_Will in forum FlashScan V2
    Last Post: May 24th, 2011, 03:33 AM
  5. Help, No licenses
    By dineauto in forum FlashScan V2
    Last Post: March 16th, 2011, 01:47 PM
