Help all GM pids are disappeared after update
now gust i have the SAE, calculated and EXT pids in the scan tool but there is no GM pids
EFILive Tuner
The problem may be that the V2 needs to be reprogrammed ...
Take a look at the thread attached below ...
http://forum.efilive.com/showthread....ing-new-update
Regards,
Taz
The problem is not in the V2 the problem is that the scan tool is not showing the GM.xxx PIDs ( i mean all GM PIDs are not there, not that they are not supported )
I already reprogrammed the V2 but still have the same problem
EFILive Tuner
Open the Scan Tool, Edit->Validate PIDs.
i think you mean info -> validate PIDs
its not active
i can't select it because its hidden
EFILive Tuner
I am having the same issue after the update.
2014 GMC 2500HD RCLB SLE
LML / Allison
It was done via check for updates
i will try to install the update directly from the web site
EFILive Tuner
