Below is the map I think I need. can't get the line through the title to go away. It shows the counts on the log, but no data to paste.
00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
The line will go away, when you select the correct pids to log for the Map.
Show us your pid selection.
Back yard boost
347+ T76 = 770 rwhp 10.96 @ 135 mph
Thanks, I got it. Changed the name of the map to match my pids.
NOW, the next issue! Why in the tutorial does this map want my B3647 to be set for 1.06 @95 map and 1.17 @1.17 ??? Wouldn't that make me tune for a super lean condition?! I have PE disabled to tune per the 2 bar map only. See photo taken of COS3 instructions below...
I would think I would want that 100 map column should be .80 so my boosted map readingsfrom there and higher will be dialed in at high 11's.
I have B3647 set to show AFR intstead of EQ and start to richen up at .85 KPA
For a boosted car you still need PE enabled
Post your tune file and i'll take a look.
Back yard boost
Which units are you using? It's under edit > Properties > Display > Commanded Fuel Values
2003 Chevy S10 4.3L LU3 LS1B Auto
48 LB injectors
Race Proven Motors 2114 intake
T70 turbo.
Thanks , its so rich , it shut off if I give it throttle to quickly . Any advice is really appreciated!
76mmcos3.tun
Did you get the tune i sent you?
Ill send you my boost tune in the morning. You should be able to copy and paste, and be running pretty good.
I forgot the AFRs in that first tune i sent you is for my N/A tune.
Ill check you your tune in the morning when i get some wifi on the laptop.
