Results 1 to 10 of 10
Thread: Cannot get wideband logging correctly with V1 analog...plx sm-afr
    Apr 2011
    Default Cannot get wideband logging correctly with V1 analog...plx sm-afr ***SOLVED***
    Hi all, finally got a chance to get my wideband installed and it is working via the digital display.
    i took the 0-5v WBoutput from the sm-afr box to the orange connector and ran the ground from the sm-afr to the orange connector.
    question 1) does the ground also have to go to a chassis ground?
    i started logging some data and my external analog voltage doesn't fluctuate, just sticks at 3.4v
    the afr on efilive hovers around 16.8ish and doesn't change even with throttle, the display gauge though changes accordingly
    this is a copy of my calc_pids file...
    *CLC-00-032
    factor 0 1 .0 "{GM.EQIVRATIO}=1"
    *CLC-00-054
    C 0.0 200.0 0.1 "{SAE.IAT.C}+(({SAE.ECT.C}-{SAE.IAT.C})*lookup({SAE.MAF.gps}, 0.0,0.799805, 10.0,0.419922, 20.0,0.282715, 30.0,0.243652, 40.0,0.219727, 50.0,0.202637, 60.0,0.188477, 70.0,0.175781, 80.0,0.164551, 90.0,0.153809, 100.0,0.143555, 110.0,0.134277, 120.0,0.124512, 130.0,0.115234, 140.0,0.106445,150.0,0.089844))"
    *CLC-00-110
    factor 0.5 1.5 .4 "{GM.EQIVRATIO}*({CALC.AFR_PLX1}/14.7)"
    *CLC-00-120
    factor 0.5 1.5 .4 "({SAE.LONGFT1}+{SAE.LONGFT2})/200+1"
    *CLC-00-220
    factor 0.5 1.5 .4 "iff({CALC.CL}, {CALC.LTFTBEN}, {CALC.WO2BEN})"
    *CLC-00-300
    % 0.0 100.0 .2 "{SAE.MAF.gps}*({CALC.DYNAIRTMP.C}+273.15)/{SAE.RPM}/{SAE.MAP.kPa}*3445.2/displacement()"
    VE 0.0 2.468 .4 "{SAE.MAF.gps}*({CALC.DYNAIRTMP.C}+273.15)/{SAE.RPM}/{SAE.MAP.kPa}*15"
    *CLC-00-320
    % 0.0 100.0 .2 "{CALC.SELBEN}*{CALC.VEN.%}"
    VE 0.0 2.468 .4 "{CALC.SELBEN}*{CALC.VEN.VE}"
    *PRN - Parameter Reference Numbers
    # See sae_generic.txt for more information on the *PRN section
    #Code PRN SLOT Units System Description
    CALC.CL F032 CLC-00-032 factor Tuning "Closed Loop (based on EQIVRATIO)"
    CALC.DYNAIRTMP F054 CLC-00-054 "C" Temperature "Calculated Dynamic Air Temp"
    CALC.WO2BEN F110 CLC-00-110 factor Tuning "BEN from Plx WB"
    CALC.LTFTBEN F120 CLC-00-120 factor Tuning "BEN from LTFT"
    CALC.SELBEN F220 CLC-00-220 factor Tuning "BEN selected from WB or LTFT"
    CALC.VEN F300 CLC-00-300 "%,VE" Tuning "Calculated VE, Not corrected"
    CALC.VET F320 CLC-00-320 "%,VE" Tuning "Calculated VE, BEN corrected"
    i am using v1, on a ls1a ecm.
    any ideas as to what the problem could be?
    94 TransAm: LS1/a4 swap...98 OS. 237/242 603/609 cam (MS3). 3600 Converter, 2.73 gears. Full Exhaust
    98 Camaro: twin 61s (in progress)...
    Which two pins on the orange connector: C and D, or E and D...?
    See attached re - Joe's post above
Name:	flashscan pinouts.gif
    Depending on whether you use pin E or pin C, the voltage pid will be different (EXT.AD1 vs EXT.AD2).
    And you have to use pin D as shown in vxchev's pic (thank's vxchev).
    Apr 2011
    i am using pin C for the 0-5V output from the WB controller
    I am using pin D for the ground output from the WB conitroller.
    i am using ext.ad1 as the voltage pid
    i added those pids into my calc_vet selection...is that correct? i thought the only pids i needed to use were the ones noted in the tutorial. i think i am overlooking something very major lol
    Apr 2011
    aw crap it should be ad2.i'll give that a shot and update!
    do i need to add the ext.ad2 PID and the calc_afr_PLX2 pids to my calc_vet selectioN?
    In your calc_pids.txt change this to use AFR_PLX2
    Code:
    *CLC-00-110
    Apr 2011
    okay i changed the calc.afr_plx1 to calc.arf_plx2
    also added ext.ad2 and calc.afr_plx2 to my calc_vet.pid file so it looks like this...
    do i need all those pids? the calcvet tutorial doesnt mention adding extad2 or calcafrplx2
    You are ok, you're at 24 pid channels.
    Apr 2011
    excellent. everything is logging correctly.
    now to start tuning before the snow hits!
  1. WO2-Analog logging with lambda instead of AFR?
    By 94SS in forum External A/D inputs
    Last Post: October 25th, 2011, 11:51 AM
  2. Logging wideband afr with autometer
    By 68sstt in forum FlashScan V2 BB Logging
    Last Post: April 28th, 2011, 09:58 AM
  3. Analog voltage not recording correctly
    By SweetS10V8 in forum General
    Last Post: December 29th, 2009, 04:07 PM
  4. Logging E38 Analog PLX AFR
    By Tre-Cool in forum FlashScan V2 BB Logging
    Last Post: March 25th, 2009, 04:19 AM
  5. PLX Wideband SM-AFR
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 22nd, 2006, 02:46 AM
