Results 1 to 7 of 7
Thread: DSP 5 switch question
    Dec 2010
    Question DSP 5 switch question
    Looking for some help on DSP Switch wiring.
    Is the ECM the voltage or current source in the DSP Circuit? Where does the computer read the voltage? Can too much amperage do harm to the computer?
    Any help would be appreciated and preferrably Ross could chime in
    Thanks!
    Andrew
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    the ecm emits 5v to the switch, and the switch limits the voltage from 1-5 is my understanding...I'm sure someone else could be more specific..
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Jul 2004
    It's a input for an oil pressure sender or the like. One side of the switch is grounded, the other connects to the ecm through an input that look like a pull up resistor to 5V.
    Unconnected that pin measures 5V or so, grounded it measures 0V. The various resistances of the DSP5 switch drop the voltage from 5V down to 1V in 1V or so steps.
    Unless you connect 12V to the switch you can't cause any harm to the ECM, and even then it might be protected.
    Ira
    Dec 2010
    So does the ground pin on the ECM since the voltage? That's where I am stuck and think the ECM is a current source and the ECM senses the voltage before the switch... Could be wrong?
    Dec 2010
    So then theoretically you can run as much current thru the DSP switch and be fine because the ECM is supplying the current?
    Dec 2010
    I am going somewhere with this. Come December, I will have a little goody for you guys
    Dec 2010
    Ross, if you are out there, do you have any insight?
  1. DSP 5 switch wire ends???
    By Dmaxxer in forum FlashScan V2
    Last Post: April 24th, 2011, 02:16 AM
  2. dsp 5 tune switch mix up
    By robertsteele in forum General
    Last Post: February 21st, 2011, 07:38 PM
  3. DSP switch components?
    By LBZoom in forum General (Diesel)
    Last Post: November 30th, 2009, 05:37 PM
  4. LMM DSP switch
    By GL4662 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 19th, 2009, 08:32 AM
  5. dsp switch install
    By numberoneshooter in forum Duramax LLY
    Last Post: April 27th, 2009, 02:46 PM
