Results 1 to 4 of 4
Thread: $0331 Error E38
    Jun 2007
    Default $0331 Error E38
    Guys finally figured everything out thanks to Ira.
    The tunes are on the AC but when I go to load into the car I get the $0331 error.
    I did a search on here and found a few people with the issue but no real answer of how to fix it . I am running the lastest greatest software released and everything else is working fine but just can not load due to the $0331 error.
    Any help would be great.
    Thanks Guys
    Jul 2004
    The help for this error is:
    Request Out of Range ($31)
    The vehicle does not support the requested OBD mode’s, sub-function’s parameter.
    Contact EFILive if this error persists.
    It would help us to answer the question if you posted all the possible information. Vehicle, OS, software and firmware versions.
    Ira
    Jun 2007
    Ira the car is
    2006 Z06
    VIN 1G1YY26E865130400
    OS 12605732
    Calibration ID 12605731
    Firmware on my V2 is 2.7.22
    Any ideas???
    Jul 2004
    Can you flash it with V8 in pass through mode?
    Did you update the scripts on the Autocal?
    Ira
  1. E40-E38-E67 B5101 Calc Error?
    By TBMSport in forum E37, E38 & E67 PFI ECM's
    Last Post: October 24th, 2011, 04:34 PM
  2. dreaded error $0331 when attempting reflash
    By gymratt40 in forum AutoCal
    Last Post: July 30th, 2011, 08:19 AM
  3. Error $0331
    By RULEMKR in forum AutoCal
    Last Post: January 26th, 2011, 09:39 AM
  4. E38 will not reflash License error
    By markemac in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2009, 08:58 PM
