Results 1 to 6 of 6
Thread: Car started to just die on me. Any ideas?
    Mar 2011
    Default Car started to just die on me. Any ideas?
    Ok.. so i was out logging ve tabbles.. And making adjustments. Everything seemed to be going good. After words on the way home .... the road to my house is a steep long rd by the way.. but i was going up it. just cruzing.. and the car just dies... so i pull over as fast as i can since this is a steep road. and crank the car.. starts right back up... i drive a short distance and did this again.. Its did this all the way tell i was home.... What could these be? any ideas?Log 752 11-17-11 dieing.efi
    If it just started happening, look for a physical problem, like MAF and/or NBO2's going out.
    Mar 2011
    Thanks will do... I should of also stated... there is not Maf. Aslo took the car out today and drove it around. And did not seem to have the probelm today. It was weird. It would just shut die..... thanks for the response.
    From your log file, it looks to me like there is a problem with your MAP sensor, it seems to respond too rapidly compared to TP...
    and the wild fluctuations in MAP seem to be driving commanded fueling, this results in your wideband reporting AFR as being all over the place, and when it gets sufficiently lean the engine dies.
    For example look at frames 10333-10633 (MAP and WO2AFR1 oscillate wildly), compare this to frames 4980-5252 (MAP and WO2AFR1 are stable).
    Your ECT and IAT seem a little on the high side.
    Mar 2011
    Thanks again... I also notice im getting code P0106, so it looks like my map sensor might be going bad?
    Junior Member Dewglass's Avatar
    Nov 2010
    Check your vacuum lines.
    '02 S10 Xtreme 4.3 Syclone power; AWD, 4L60E; 411 PCM: Walbro 255; 160F thermo: Front coil overs, 4" static drop;
  1. Replies: 1
    Last Post: October 16th, 2008, 11:01 AM
  2. Did my V1 die?
    By joeygc5 in forum FlashScan V1
    Last Post: May 7th, 2008, 12:26 AM
  3. Caution thread...my RR started to die in a strange way.
    By onfire in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 19th, 2007, 09:08 AM
  4. Car started running rich and miss firing
    By Darkness in forum General (Petrol, Gas, Ethanol)
    Last Post: January 12th, 2007, 04:11 PM
  5. Tries to die when put in reverse
    By 1SlowHoe in forum Gen III V8 Specific
    Last Post: January 5th, 2007, 04:16 PM
