Results 1 to 7 of 7
Thread: Updated software now progress window disapears when flashing
    Mar 2009
    Default Updated software now progress window disapears when flashing
    I updated my software the other day, then reflashed a LLY, during the reflash my progress window disappeared so I had no idea what was going on. The window finally came back when I got the turn off IGN count down. I dont like not being able to watch the progress, any idea whats going on? Also I couldnt get the darn tire calc to change from metric to imperial even after changing the setting.
    Shawn
    98 silverado 4wd excb 5.7l, zz4 cam,roller rockers, shorty headers, 0411 swap, Flash Scan V1 commercial
    Hi Shawn,
    What build did you upgrade to...?
    Quote Originally Posted by haulinit View Post
    Shawn
    The window disappearing is a Windows thing. Just press Alt+Tab to cycle the display back to EFILive's main screen and Windows will bring the progress display back to the front.
    Did you change the speedo settings using the settings shown in the image below?
    Mar 2009
    Thanks Blacky yes I changed it with that screen, everything else changed but the tire calc. Joe I'm not sure which build it was I hadnt updated in some time.
    Do Help->About.
    Mar 2009
    V7.5.7 build 180
    Do you mean the speedo calc window is not changing from metric to imperial and vice versa?
    If so that is correct, it will always display both metric and imperial values.
  1. Progress with headers
    By cmitchell17 in forum Gen III V8 Specific
    Last Post: January 31st, 2008, 01:22 PM
  2. Replies: 22
    Last Post: January 8th, 2007, 01:15 PM
  3. EFILive 7.3 pre-release software has been updated - again
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: August 24th, 2005, 08:44 AM
