Howdy again. I have two questions that revolve around using the AMS-1000 boost controller.
The AMS-1000 uses a 0-5 volt signal to identify what gear the transmission is in. Are there any such provisions on the factory 4l80e which I could use or make a gear indicator box from? I was hoping to leave the transmission in drive while at the track. I was thinking of using signals from the shift solenoids or something to accomplish this.
If that is not possible I can use the dakota digital box if the transmission was manually shifted. I was thinking of using switches on the right pins to trigger "manual mode." Is that safe to use at the track? Will lock up still function..etc etc.. I would think this is the easiest way to accomplish my goals.
Thanks,
Steve
