Results 1 to 10 of 11
Thread: defuel tables
    Oct 2009
    Default defuel tables
    I was wonting to know what table to change to get rid of some defuel
    Mar 2009
    Look under the engine torque tables inside the engine calibration portion. They all pertain to how much torque the ECM tries to theoretically limit the engine to.
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Torque limited injection quantity is one to play around with a bit.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Oct 2009
    where should i start playing at in that table
    Mar 2009
    Quote Originally Posted by crash85 View Post
    Careful with the TLIQ table. It controls max fueling as well as how much it defuels on shifts. If you go to big it wiull not defuel at all and even fully built trans cn come unglued running without defuel. It is the table though that has the most control over max defueling, and is teh table referenced teh most for how much fuel to give for a defuel request.
    Oct 2009
    where at in the table do i need to start my changes
    Mar 2009
    It all depends upon what your after. You just basically start making changes until you find where you need them changed at.
    Lifetime Member LB72004's Avatar
    Dec 2011
    looks like you need to start logging
    Jan 2012
    what would a guy log to see where to adjust this table so the defuel is not so aggresive.
    Nov 2009
    mm3- see the drop during the shift, adjust TBIQ accordingly.
    -Kory
    http://www.PPEI.com/
  1. Help with defuel
    By johnj in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 6th, 2011, 03:25 AM
  2. Defuel affect
    By SGFastMax in forum Duramax LB7
    Last Post: May 5th, 2010, 11:59 AM
  3. LMM defuel
    By lawnboy01 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 30th, 2009, 12:16 AM
  4. defuel question
    By saltflat in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 2nd, 2009, 06:41 AM
  5. Killing Defuel?
    By Cougar281 in forum General (Diesel)
    Last Post: October 25th, 2007, 06:05 AM
