Well, it's gonna be a while before I do any logging....the dang t-case just went T.U. for the second time. No cash for a rebuild so the truck's gonna sit for a few months. Grrrrrr...
Separate note: I found a cell for Stoichiometric ratio. Since all I can get usually is E10, should I go ahead and change that? Depending on fuel mixtures E10 is usually around 14.1, whereas straight gasoline is 14.7. Any other tables to modify for that?
Thanks all.
