Hi guys,
Some questions for the experienced amongst us.
It seems no matter what timing Im running whether at a certain level or 10 deg retarded I can always get the odd little spike of KR.
Its not logged as the raggard saw tooth of actual sustained knock, more like the odd litte spike now and again, generally during throttle and mid to large airflow transitions. This is in OS3 on an OLSD tune.
My question is should I worry about this, or is the odd tick now and again indicative of "false" knock or just the general action of a busy engine during transitions? (ie) Should my logs always and never have any KR logged at all, not even 0.2 deg etc?
Im going to do some tuning on a dyno after my cam install in the mid term and I was also going to run my stock (puke) tune and see if it exhibits the same behaviour.
Just wondering what you guys see and experience.
