Results 1 to 3 of 3
Thread: V2 Com Port settings and firmware updates.
    Nov 2011
    Unhappy V2 Com Port settings and firmware updates.
    Hi,
    i am a newbie on the forum, but i have done my best to research before posting. i have recently updated my V2 flashscan firmware and boot blocker. i followed the tutorial but i am not sure if i have made mistake. i have the latest 2.07.22 firmware and 2.07.03 boot blocker. my problem is this:
    After trying to follow the serial wideband tutorial, i noticed that they require change Com-port in and Com port Out, and i only have one Com port setting (no com port in and out as per tutorial).
    my question is: am i on the right track or have i missed something with my firmware update.
    i think i could have skipped a step with the firmware update. and should have to reset my firmware somehow and start all over .
    can some help please.
    Your help is appreciated.
    No, if its an Innovate then ignore their documentation on this. Make sure the null adapter is plugged into the COM IN port on your WB controller, then connect a cable between the COM OUT and your V2. Set the WB controller to be the correct manufacturer and program your V2. Should be good to go. It confused me a little at first, but then I realized the COM IN is for programming the controller or daisy-chaining multiple together.
    Set your V2 as shown:
  1. serial port cable that goes to v2
    By articSS in forum FlashScan V2
    Last Post: August 19th, 2014, 12:57 PM
  2. Firmware Updates
    By BullfrogJohnson in forum General (Diesel)
    Last Post: June 18th, 2008, 06:59 AM
  3. Calibrating AD port
    By stigmundfreud in forum Black Box Logging
    Last Post: March 31st, 2008, 12:21 AM
  4. OBD Port Question
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 4th, 2007, 01:00 PM
Tags for this Thread
