Results 1 to 2 of 2
Thread: 07.5 LMM won't take dsp5 tune
    Mar 2010
    Default 07.5 LMM won't take dsp5 tune
    So I'm tuning this lmm and it will not change off of the base tune. I check my pids for the switch and it shows the voltages and tune numbers changing the way they should. Also adjusted my voltage settings in the tune accordingly. I can get it to work before I run a script on it but not after. The script is good because I've used it on another lmm with no problems. I even copy and pasted every cell and it would not work. Has anyone run into this before? Is it because the script is from an 09 lmm? I'm at a loss here
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Is it sucessully completing the full flash into the truck? If so..check your tune.voltages via scan tool
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
  1. LMM DSP5 EGR Referencing?
    By North Maine in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 3rd, 2011, 08:38 AM
  2. Lmm dsp5 issue!
    By cumminsDK in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 7th, 2010, 11:47 AM
  3. LMM-dsp5 time delay
    Last Post: June 3rd, 2010, 03:17 PM
  4. Lbz/lmm dsp5
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 10th, 2010, 03:16 PM
  5. TRUCK WON'T START AFTER DSP5 instal
    By vortecfcar in forum General (Diesel)
    Last Post: June 8th, 2007, 05:43 AM
