When ever I'm at a slow roll and go to WOT, the trans kicks back to low gear as it should. The tires start spinning and when rpms hit about 5300 an unkown rev limiter activates. My rev limiter is set at 6500 and works there when excessive wheel spin is not happening. I can't find anything in the EFIlive tables to correct this. Anyone else ever had this problem?
