I will be buying a v2 in the next week or 2 and I have a question. I have a 2002 Lb7 Duramax with a slight of smoke at start up and right off idle. My truck isn't seeing/reading the barometric pressure sensor. It sees and reads the map but not the baro. I've tested all 3 wires on the baro plug, everything checked out ok. When I read what little bit I can with my diablo I get a reading of 14.3 intake manifold psi and 2psi boost with engine off key on. If I unplug the map the boost goes to 0 and the manifold pressure goes to 7.3, however if I unplug the baro nothing changes. I've replaced both baro and map, still no change. My question is, with the efilive tuning and v2 is there a way to delete or set the baro to "0"? And by 0 I mean at or slightly above sea level. I live in Fl so changes in elevation don't happen.
Sorry for the long read, hopefully someone can help! Thanks.
Sint frum tha orijinul smert fone
