Results 1 to 10 of 13
Thread: Sensor removal?
    New Member 02greysixer's Avatar
    Nov 2011
    Default Sensor removal?
    So I will be buying a v2 here shortly and I hope it can fix my problem. I have an 02 Lb7 and My truck is completely ignoring the barometric pressure sensor. Its like its not even plugged in and I've checked all I know to check. Even replaced the baro and map. Still no change. Can the barometric pressure values be set to "0" with efilive? And by 0 I mean slightly above sea level. I am in Fl so changes in altitude don't happen all that often :rofl: Truck runs great, just smokes a bit at first start up and right off idle, and I am assuming it is because the truck is over fueling because it is starting at 2psi boost instead of 0.
    Thanks!
    Sint frum tha orijinul smert fone
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Yes you can. Question. Where in FL are you. We'll be in the state this week and can look at the truck to see if we can figure out your issue. If not we'll have V2s with us. We're going to Orlando then South Palm Beach. My guess is you have a bad wire somewhere.
    Dan's Diesel Performance
    Specializing in Duramax and Cummins Diesels
    Building and tuning trucks from daily drivers to full out competition
    www.dansdieselperformance.com
    Nov 2011
    I am in between St Augustine and Gainesville. In palatka, 32177. I have checked all the wires, all have good grounds, good power, and even checked the signal wires going from the baro and map to the computer and they have no breaks or shorts either. Will you be anywhere near here?
    Apr 2009
    Shows you being about 4.5 hours from where we'll be. If you wish to take the trip north to meet we can see what we can figure out. We'll have some V2s with us plus can tune it also if you want.
    Nov 2011
    Thanks! I doubt I will have time to make the trip though unfortunately. I was just mainly curious if it was possible to alter the baro readings.
    Apr 2009
    Yes it is. We can ship you the V2 when you're ready to purchase.
    Jan 2006
    I don't see baro scaling. ??
    Custom Tuning Services
    Nov 2011
    Cool, thanks!
    Apr 2009
    You can change the baro values which determine which maps the ECM uses. So if sensor is removed you would log the baro sensor and see what psi it reads then set all three baro values to that number. That will force it to use map C all the time. Best thing to do would be to fix the problem as this would be like sweeping dirt under a rug.
    Nov 2011
    I took my harness all apart and tested all 3 wires for both map and baro. Both had 5v power, a good ground and the signal wire showed little to no resistance between the sensor plugs and the big plug to the ECM. At this point I don't know how it could be fixed right, short of maybe trying a new ECM?
  1. 6L80 TM removal?
    By SRT10KLLR in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: October 23rd, 2012, 06:50 PM
  2. Cat removal
    By pjaneiro in forum General (Petrol, Gas, Ethanol)
    Last Post: August 16th, 2008, 08:58 AM
  3. MAF removal question
    By s10mods in forum Gen III V8 Specific
    Last Post: October 5th, 2007, 02:04 AM
  4. Removal of speed limiter
    By 06-6.0 SierraHD in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 20th, 2007, 04:49 PM
  5. Traction control removal
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: August 9th, 2006, 05:56 PM
