Results 1 to 4 of 4
Thread: Tune help not going into PE
    Oct 2007
    Default Tune help not going into PE
    99 camaro with 02 operating system, maf im not getting any fuel at wot AFR stays 15:1 mods are heads,cam
    May 2010
    What is fuel pressure at wot? What size injectors?
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    Can you post a log file also.
    Oct 2007
    Here is the log. Stock injectors , 58psi at WOT. Wideband was not connected to EFIlive in this log
  1. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 09:16 PM
  2. Replies: 5
    Last Post: October 3rd, 2010, 11:16 AM
  3. Replies: 5
    Last Post: August 5th, 2008, 02:35 PM
  4. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
  5. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
