99 camaro with 02 operating system, maf im not getting any fuel at wot AFR stays 15:1 mods are heads,cam
What is fuel pressure at wot? What size injectors?
1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
Here is the log. Stock injectors , 58psi at WOT. Wideband was not connected to EFIlive in this log
