Results 1 to 5 of 5
Thread: Don't forget your correction tables...
    Apr 2011
    Default Don't forget your correction tables...
    I was running through my tune last night and got thinking about the considerably advanced timing from stock. As I looked through the correction tables, it became apparent that, given the right conditions (e.g. cold ect) the computer would push the timing WELL beyond safe (although it is capped in the timing limiting table). In some cases it will add as much as 25 degrees. IMHO, Since most of us run close to the limit, this could cause real problems.
    The next step was how to correct this? Here's what I did...
    Using Excel, compare the stock timing with your current timing. Take the difference and, using 'paste and subtract' in EFI live, copy it to your correction tables.
    This SHOULD keep the correction in line with stock, while allowing you to advance your base timing.
    If I am way off base here, please let me know...
    Jan 2006
    Good post.
    Some year groups have a timing cap table. That is a good place to spend the insurance money.
    Custom Tuning Services
    Oct 2010
    Thats good idea though cause with my advanced timing I can hear some rattle when it's cold so correction table correction really should be taken into account.
    Lifetime Member LB72004's Avatar
    Dec 2011
    here is an excel sheet that someone else posted up a while back that i have been using with good results
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Jun 2009
    On my LMM I limited timing in B0956 and B0962 for example to 15 maximum in all cells that were greater than 15. All other cells were left alone and my cold temp rattles were gone.
    These are the ECT Timing correction tables BTW.
  1. Difference between (A) and (B) timing correction tables (LBZ ONLY)
    By bballer182 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 12th, 2010, 01:51 PM
  2. Speedo Correction
    Last Post: April 8th, 2007, 08:46 PM
  3. Which tables don't affect DIC calcs
    By Wasted Income in forum Duramax LLY
    Last Post: April 6th, 2006, 01:42 PM
  4. IAC correction pids not available.
    By camdavgar in forum General
    Last Post: December 20th, 2005, 01:27 AM
