I have this in the PID text file
# File details
# This section defines various details about the file format.
*FILE
#Parameter Value Description
VERSION 7.1.1 File version
DECSEP . Decimal separator used in this file
# Units
# See sae_generic.txt for more information on the *UNITS section
*UNITS
#Code System Abbr Description
MPG Imperial MPG "Miles Per Gallon"
# Add slot definitions here
# -------------------------------- ({SAE.VSS.mph})/({GM.INJFLOW.lbpm} *{GM.IBPW1}* {SAE.RPM} * 2 / 6250 )"
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*CLC-00-003
MPG 0.00 99.99 .1 "{SAE.VSS.mph}/({GM.INJFLOW.lbpm} * {GM.IBPW1} * {SAE.RPM} * 4 / 6250 )"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.MPG F003 CLC-00-003 MPG Fuel "Miles Per Gallon"
When I cick "save" and close, save the PID as it prompts, reopen the scanner, I see the PID for MPG and I can scan and read data! Great! Whoopie!
Now I want to ADD ANOTHER PID
So back to the PID text and I do this:
# Units
*UNITS
WBAFR None WBAFR "WB Air Fuel Ratio"
*CLC-00-002
WBAFR 10.00 20.00 .1 "{EXT.AD1}*2+9"
CALC.WBAFR F002 CLC-00-002 WBAFR Fuel "WB AF Ratio"
Click "save", close up, save the PID as prompted & reopen the scanner and the MPG is gone but the WBAFR Pid is there. DAMN! Why don't I see BOTH of the PIDs that I created!
Elmer
