Results 1 to 2 of 2
Thread: "Attached PCM's serial number is missing"
    Jun 2005
    Unhappy "Attached PCM's serial number is missing"
    Went to start up my car and it would die with any throttle.
    It was throwing MAF codes but haven't run a MAF in a year CLSD.
    I attempted to upload the existing tune with no success. Serial number blank not detected. Screen prompted me to "Please perform a full reflash of this PCM."
    Pulled PCM and discovered corrosion in the left blue connection. The other blue and both reds looked fine.
    Is my PCM bad?
    I wasn't tuning and hadn't logged or flashed in a week at the time of the incident.
    Thanks for any help!
    Christopher's -10cc Alum 6.6L '01 T/A FIREHAWK Recaro Topline Leather/Suede Seats
    Ported L92 Heads, Custom Cam, L76, F.A.S.T. 90TB, 104Lid, CLSD, Kooks 1 7/8 stepped 2", 3" True Dual X-pipe over-the-axle, 3.90 gears, Tubular K, Upper/Lower tubular A-arms, full UMI suspension, etc.
    Brenda and Her Custom Red/Black '01 WS6 Performabuilt stalled A4, Custom Cam, Kooks 1 7/8", 3:42, lid/K&N, Loudmouth, Full Custom Interior, Playboy Package.
    Can you get the corrosion cleaned up (you will have to open the PCM case and see if the pins have continuity to the inside)...?
  1. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  2. lean LTFTs, logs attached (NB "tuning")
    By Boost in forum Gen III V8 Specific
    Last Post: October 2nd, 2010, 02:58 PM
  3. T42 With Missing "Shift Times" Parameters
    By swingtan in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 26th, 2009, 10:14 AM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
