Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: No Balance Rate PIDs?
    New Member Heartbeat Hauler's Avatar
    Apr 2006
    Default No Balance Rate PIDs?
    The truck has started smoking so I wanted to check the balance rates....first time. Anyways, I went to select the PIDs for injectors 1-8 and there are NO Balance Rate PIDs. I do have something called Injector Duty Cycle, but I don't think this is it.....I'm sure.
    I am running 7.5.7 (Build 180), I have selected the proper controller E54 LB7 Duramax ECM in the DVT. I don't have an LB7 Duramax PID file to select from in the PIDs Tab, only a LBZ imperial and metric and Duramax Default.
    I would appreciate dome help on this as to why I do not have the Balance Rate PIDs....thanks.
    2001 Dmax/Alli 3500 LS 4x4, Banks 4" Exhaust & Big Head WasteGate, Bilsteins, VR Straps, Racor 660 Secondary (Pre-OEM) fuel filter kit
    2004 Suburban 2500 LT 6.0
    1996 Chevy Caprice LT1
    3500 Dually Club - Member #187
    Aug 2008
    I am having the same problem
    Apr 2008
    Same version and have them.
    Code:
    OK	DESCRIPTION	CAPTION	UNITS	SYSTEM	CH	PARAMETER
    -	Alternator F-Terminal Counts	ALT-F	%	Conditions	1	GM.ALT-F
    -	Ambient Air Temp	DYNAAT	°C,°F	Dyno	4	EXT.DYNAAT
    -	Ambient Air Temperature	AAT	°C,°F	Temperature	1	SAE.AAT
    -	Anti Theft State	VTD		Fuel	1	GM.VTD
    -	Atmospheric Correction Factor	DYNATMCOR	Counts	Dyno	4	EXT.DYNATMCOR
    -	Auxiliary Input Status	AUXIS		Conditions	1	SAE.AUXIS
    -	Balancing Fuel Flow Rate Cylinder #1	BALRCYL1	mm3	Diesel	2	GM.BALRCYL1
    -	Balancing Fuel Flow Rate Cylinder #2	BALRCYL2	mm3	Diesel	2	GM.BALRCYL2
    -	Balancing Fuel Flow Rate Cylinder #3	BALRCYL3	mm3	Diesel	2	GM.BALRCYL3
    -	Balancing Fuel Flow Rate Cylinder #4	BALRCYL4	mm3	Diesel	2	GM.BALRCYL4
    -	Balancing Fuel Flow Rate Cylinder #5	BALRCYL5	mm3	Diesel	2	GM.BALRCYL5
    -	Balancing Fuel Flow Rate Cylinder #6	BALRCYL6	mm3	Diesel	2	GM.BALRCYL6
    -	Balancing Fuel Flow Rate Cylinder #7	BALRCYL7	mm3	Diesel	2	GM.BALRCYL7
    -	Balancing Fuel Flow Rate Cylinder #8	BALRCYL8	mm3	Diesel	2	GM.BALRCYL8
    -	Barometric Pressure	BARO	kPa,PSI	Air	1	GM.BARO
    -	Barometric Pressure	BARO	kPa,PSI	Air	1	SAE.BARO
    -	Barometric Pressure	BARO2	kPa,PSI	Air	1	GM.BARO2
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Aug 2008
    Thumbs up
    How did you get that
    Apr 2006
    Good idea, it might help if you went through the procedure to get to that point. Because I have tried a bunch of different things and it is obvious that the Balance Rate PIDs are not there. Thanks.
    Apr 2008
    I just start up the Scan app version build 180. Goto the PID tab and have the PID File selected as Default pid and the ALL for the System option on that page. Even if selecting the PID File as Duramax Imperial and Duramax LBZ Imperial they still show up.
    Went out and connected to my LMM and they show data off them. the steps I did
    Connect the Flashscan V2 to the laptop and let the USB interface register the device.
    Connected to the OBDII port.
    Started Scan app
    Hit the connect button and selected the LMM module.
    It validated PIDs.
    Selected the Injector PIDs and some others.
    Went to the Data tab and hit the yellow monitor button to start viewing data.
    I included a pic of the screen.
    At first I got an ERROR 11 but determine I had a PID that is not valid. Be nice it tell you what was invalid but its soon to be outdated software. it may have been my fault since I selected the PIDs before going out. I just redid it as i described above to confirm it works for me. At least in BBL it will continue if you select a bad PID so you can remove at a later time. Included a screen shot of the PID data I had up and running. Also went and directly used the BBL feature and it shows the data fine directly on the Flahscan V2 itself.
    Brian
    Apr 2006
    Yep, exactly what I am doing and no Balance Rate PIDs to be found. I don't get it, this has got to be a download issue.
    Thanks Brian, I appreciate the effort. I gotta get this figured out. Maybe I forgot to download something, or I'm missing an update, but these PIDs should be there. I wish I would have checked this issue before I downloaded version 7.5...bummer.
    Oct 2011
    Try unchecking the "supported" box
    Apr 2006
    Quote Originally Posted by Compcowboy View Post
    Not checked....bummer.
    Apr 2008
    How long has this been on your system?
    Updated many times since first installed?
    Try this. Back up any tunes you have which should have already be for safety if you lose a harddrive. Uninstall both pieces of software. Rename the EFIlive directory under your Documents folder. Download a fresh copy of both pieces of software and install. Verify both firmware and bootblock are up to date. Then try again to find the balance rate PIDs.
    Brian
  1. Injector Balance ?
    By icemanjc1 in forum Cummins 5.9L
    Last Post: September 30th, 2011, 01:39 PM
  2. Cyl. Balance Test
    By FstBlkZ28 in forum General
    Last Post: June 9th, 2009, 03:38 AM
  3. Injector balance test
    By odd boy in forum General
    Last Post: October 12th, 2008, 04:50 AM
  4. Balance rates
    By diesel freak 123 in forum Duramax LB7
    Last Post: April 22nd, 2008, 02:55 PM
  5. Cylinder Balance Test
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2006, 12:49 PM
