What is the name of the pid that tells you which table it is using when in open loop?
Black 1999 Blown Convertible
Forged 383
ATI D-1SC-1, NX MAF Kit, 222/226 .585 115
AS Stage II 6.0L FI Heads
526.1 RWHP - 521.4 RWTQ - 10# - P1
666.0 RWHP - 734.2 RWTQ - 150 Shot - P1
2008 Black Yukon Hybrid 4WD
www.ls1.com
{SAE.FUELSYS}
{GM.STATE05} (right click and select more info to see the status flags.)
Thanks, but that won't tell me which table its looking at.
My issue that I am trying to fix is I cannot get the AFR any leaner than 10.xx in open loop.
Was hoping there was a pid that would help.
I assume that is commanded AFR, not actual?.Originally Posted by Ed Blown Vert
Its actual, I have a wideband installed.
Originally Posted by GMPXThis is a quote from a thread on Tech.Originally Posted by Ed Blown Vert
IFR out of whack, VE out of whack, MAF out of whack, PE out of whack... AFR out of whack.
Hmm....thats alot of helpOriginally Posted by joecar
Forged 383
www.ls1.com
Sorry, my comment was pretty lacking... I don't know what heppened...Originally Posted by Ed Blown Vert
I meant to say to use the Speadsheet to recalculate the IFR table and then try an Auto VE tune (and recal the MAF table from this, or just run SD) and see what happens, but you've probably already been thru all that.
Joe
P.S. Nice car.
