Results 1 to 10 of 11
Thread: CalcVET Question
    Jan 2008
    Default CalcVET Question
    I tried the CalcVET and when I copied over to the Main VE table the data doesn't look right to me. Could someone help me with what I did wrong. Thank you.
    Here is a copy of my log and tune file:
    2006 GMC CCSB 1500HD 4X4 - Radix 3.2 pulley, Pacesetter Long Tubes, Magnaflow exhaust
    This is what I get from your files:
ID:	12376 Click image for larger version.
Name:	B0101 VE pasted from VET map.png
    (remember the VET map is pasted-with-labels straight into the VE table)
    Post pics of your map and the VE table after you past-with-labels.
    Jan 2008
    Here is what I come up with
ID:	12378 Click image for larger version.
    This is without smoothing the VE table but my concern was with numbers going from the 40s, 50s, etc. down to 1-2.
    Jan 2008
    Sorry, here is the VE table
    Jan 2008
    Here is the VE table after smoothing:
Name:	Smoothed B0101.png
    My numbers are different than yours so I'm not sure what I'm doing different.
    Ok, this is the problem: your tunetool is displaying B0101 VE table in units [%], whereas your scantool map is displaying in units [g*K/kPa].
    So you have to be sure to use the same units in tunetool and scantool;
    you can do this by doing one (and only one) of these:
    - in the tunetool, go Edit->Properties and set the VE units to g*K/kPa,
    - in the scantool, for the map data use CALC.VET.% (i.e. the one with % units);
    when the units match, your scantool map data would be much closer to the VE table cell values.
    BTW: remember to:
    - eliminate map cells that have low count (empty).
    - apply the transient filter.
    Jan 2008
    Under edit map properties > empty (tab) I checked hide empty cells and set the low count to 10. Is there something else I should change?
    Quote Originally Posted by BlackSS View Post
    10 or 20 is fine.
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 10:10 AM
  2. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 02:22 PM
