This is a prayer for help for a known problem that exists on every LLY. This one had a more prominent set of symptoms, while all LLY trucks have this issue to some extent. It has been discussed in other threads. This screen shot shows the fully warmed up idling truck, first in gear, then in Park/Neutral. The ONLY commanded change is main timing. The first half of the chart (-5.0 timing) is characterized by:
1. chugging white cold-smoke
2. idle rpm instability (lope)
3. 50-70% more fuel consumption
4. Failed emission test (8X opacity)
5. LOTS of dirty looks.
6. More "what's that exhaust smell in traffic" threads.
As soon as the truck is put in park (-1.0 timing), all these problems resolve, and smooth, clean, efficient, and economical operation resumes. As I see it, this problem is more prevalent in the winter and with EGR blocked. Multiple sources have confirmed the same observation. Specifically, the -5.0 timing has trouble maintaining auto-ignition with the cooler air. The simple fix to this, is to adjust main timing during in-gear idle. To date we have no adjustabilty, except for P/N. I have been using a workaround that I will avoid discusing, in hopes of addressing this properly (if possible). I know we can really improve economy with this one issue solved.
