$800 is overpriced... various cam makers will custom grind for a lot less.
The problem is the give-take relationship has been one sided.
Well. I need a custom cam blank since so far I haven't found anyone that makes a cam for the LZ9LZG engine.
Internal parts then externals...
More rhetoric and attempts at subterfuge … actually you missed your calling as a politician. The “real issue” is unwavering, and has not changed since your arrival in this Forum … which is your attempt to steal or misuse the intellectual property of EFILive.
All of your double speak and cognitive gymnastics are only attempts to defer the attention of others away from the “real issue”.
The thread linked below is quite clear …
http://forum.efilive.com/showthread....p-E38-hardware
The intent of this response is to alert the Forum membership of:
- your improper intentions
- remind them that you are not an EFILive customer nor software user (you don’t own a V1 or V2)
- that answering any of your questions my inadvertently contribute to a theft or misuse of EFILive’s intellectual property
Anytime you post on this Forum, I will remind the membership to think carefully before responding.
