Results 1 to 4 of 4
Thread: Logging RPM
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Default Logging RPM
    I am having trouble logging RPM with the blackbox - it all works fine via the laptop. But the BB files have either very low rpm counts or in the last one zero.
    Hoping someone can help. What am i doing wrong.
    Quote Originally Posted by Flyer
    The problem is currently under investigation.
    Are you using dynamic scan mode with more than 24 channels? If so, try reducing the channel count to 24 or less and using 10fps-Fast (also known as Stream-fast).
    Nov 2005
    Default Rpm
    I tried programming less pids (12 channels only) and done in fast and in dynamic.
    The last one had these pids installed in the black box.
    PRI CAPTION DESCRIPTION VALUE UNITS MIN AVG MAX PARAMETER
    1 TP Absolute Throttle Position 0.4 % 0.0 8.5 100.0 SAE.TP
    1 BEN_PLX1 Base Efficiency Numerator 1 - PLX 1.0 factor 0.7 1.0 1.3 CALC.BEN_PLX1
    1 AFR Commanded Air Fuel Ratio 14.52 :1 12.96 14.45 14.63 GM.AFR
    1 ECT Engine Coolant Temperature 158 °F 158 190 210 SAE.ECT
    1 RPM Engine RPM 0 RPM 0 0 0 SAE.RPM
    1 AD1 External Analog Voltage 1 2.46 V 0.16 2.10 4.80 EXT.AD1
    1 AD2 External Analog Voltage 2 3.60 V 3.60 3.74 3.79 EXT.AD2
    1 TEMP External Thermocouple Temperature 32.0 °F 32.0 32.0 32.0 EXT.TEMP
    1 SPARKADV Ignition Timing Advance for #1 Cylinder 15.5 Degrees 0.0 23.8 39.5 SAE.SPARKADV
    1 IAT Intake Air Temperature 136 °F 99 110 136 SAE.IAT
    1 MAP Intake Manifold Absolute Pressure 15.7 inHg 4.1 13.6 29.2 SAE.MAP
    1 KR Retard Due to Knock 0.0 Degrees 0.0 0.0 3.0 GM.KR
    1 VSS Vehicle Speed Sensor 0 MPH 0 30 83 SAE.VSS
    1 ACCDEC Wheel Acceleration/Deceleration 1 Counts 1 1 1 GM.ACCDEC
    1 AFR_PLX1 Wide Band AFR 1 - PLX 2.5 V 0.2 2.1 4.8 CALC.AFR_PLX1
    1 AFR_PLX1 Wide Band AFR 1 - PLX 14.9 AFR 10.3 14.2 19.6 CALC.AFR_PLX1
    I dont need them all installed do i. Which ones can i get rid of (from the black box logging pids)??
    I know plx channel 2 is one of them.
    It seemed that RPM didnt work and neither did ACCDEC Wheel Acceleration/Deceleration
    Nov 2005
    Just validated pids again and all is well with 11 channels on fast 10fps logging.
  1. Logging LMM's
    By schuter in forum Diesel
    Last Post: March 20th, 2008, 02:26 AM
  2. Logging L76
    By JezzaB in forum Gen IV V8 Specific
    Last Post: June 11th, 2007, 11:10 PM
  3. VE after logging
    By Beer99C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2006, 01:28 PM
  4. I have a few Q's about logging.
    By SmaknSS in forum General
    Last Post: December 1st, 2005, 06:33 AM
