Results 1 to 2 of 2
Thread: CASE Crankshaft Relearn with E37?
    Oct 2011
    Default CASE Crankshaft Relearn with E37?
    There is no E37 'Target Controller' under DVT (Dynamic Vehicle Testing) in the Scan Tool V7.5 edition, thus, I cannot get to the crank relearn procedure. All posts I find tell about the routine once you get through accessing DVT. Anyone know the correct procedure?
    http://forum.efilive.com/showthread....-crank-relearn
    Just select the DVT target controller as an E38, it should work fine.
  1. Custom operating systems and crankshaft relearn?
    By 94SS in forum Custom Operating Systems
    Last Post: October 10th, 2011, 01:42 PM
  2. Case Relearn
    By sheamus in forum Lounge
    Last Post: June 20th, 2009, 04:35 AM
  3. case relearn
    By 67LS3 in forum Gen IV V8 Specific
    Last Post: October 23rd, 2008, 02:52 PM
  4. CASE Relearn
    By Fratsit in forum General
    Last Post: February 7th, 2007, 10:39 AM
  5. CASE Relearn after Flash
    By GMPX in forum General (Diesel)
    Last Post: November 24th, 2006, 05:15 AM
