Hello, I have read the following thread regarding the use of the flat response vs resonant type sensors and did not see an answer to my current question,
http://efiforum.iqd.co.nz/showthread...=5507#post5507
I would like to know if anyone has successfully implemented the use of the LS2 "Flat-response" sensor with the LS1 PCM?
Within EFI Live's calibration set up for the LS1, I found the following:
http://efiforum.iqd.co.nz/attachment...1&d=1137857426
There is a typo regarding the pins for the resonant single wire. It is not pin 56 but pin 51 that is used:
Anyhow I have a few customers that are doing LS2 installs into these 2000 - 2004 MY Y cars and would like to use the LS2 sensors. It looks as if this is possible but wanted to make sure that I was not headed in the wrong direction. Any other issues regarding the set up of these sensors I should be aware of.
Thanks for your time.
Regards,
