Results 1 to 10 of 13
Thread: Help please....2005 Corvette E40 missing Stoich parameter????????
    Senior Member mowton's Avatar
    Oct 2008
    Default Help please....2005 Corvette E40 missing Stoich parameter????????
    Gonna try this question one more time. Can not find the Stoich cell(s) in this E40 PCM file from EFI Live (HPT does). We are converting to E85 and would like to make a change to 9.8 but simply can't find it. Is the PCM OS operating in just lambda? What am I missing?
    i'm operating in open loop.
    Thanks again and have a happy and safe Holiday season....oh well, to hell with PC...Merry Christmas
    Ed M
    Lifetime Member Chalky's Avatar
    Sep 2003
    Ed:
    Here's a bump. I just opened a 05 E40 file and cannot find stoich table either.
    Merry Christmas to you!
    2015 Z06 A8
    Oct 2011
    i havent actuallyd done an e85 conversion on the E40 but i have been working on mine lately and learning alot......i beleive all you are going to need to do is adjust the b0141 Open Loop Commanded Fuel table to refelct the target AFR you need now.......i couldn't find the stoich parameter either i beleive its different in the E40 vs the older ECM's.....
    We can take a look for it but it's been a while since I looked at the E40. We are about to release a new update, I doubt it will make it in to that, however, I'll try for the next.
    Oct 2011
    i hope it affects some of the E40 stuff....theres a few things in the software i ran into on the E40 pcm that are labeled odd.....figured them out but just odd lol
    Such as? If there is issues I can try to fix them at the same time as adding the Stoich table.
    Oct 2008
    Thank you...any estimate for release? In the mean time, I would assume that the stoich value is locked at the factory 14.68 or if changed by HPT, would remain that value when tune was then pulled with EFI Live, modified other tables and re-flashed?
    Ed M
    The Stoich table was added for the next release, which should be out before Christmas.
    Oct 2011
    heres two of them i can recall right now.....
    first is the Max Idle Area 1 and Max Idle Area 2 in the Idle>paramaters tab........it seems as though they react backwards.....idle area 2 seems to be not moving and the idle area one seems to be while the car is in motion.......not a big issue just something i noticed....
    second is how is this table to be adjusted i cant seem to make heads or tails out of what the table is showing??
    all in all i love the software espically the auto tune features
    thanks!!!
    Mike
    Aug 2010
    Quote Originally Posted by quik95lt1 View Post
    ... first is the Max Idle Area 1 and Max Idle Area 2 in the Idle>parameters tab........it seems as though they react backwards.....idle area 2 seems to be not moving and the idle area one seems to be while the car is in motion ...
    B1651 (Max Idle Area 1) - is for non-stationary idle control (same as E38 / E67).
    B1652 (Max Idle Area 2) - is for stationary idle control (same as E38 / E67). In the EFILive description of this it states "used to prevent the vehicle creeping forward when the brake is depressed" - implies that the vehicle is not moving (stationary).
    The EFILive descriptions of B1651 & B1652 are the same for E40 / E38 / E67.
    Regards,
    Taz
  1. 2005 E40 Corvette file
    By mowton in forum Gen IV V8 Specific
    Last Post: December 8th, 2011, 02:06 AM
  2. cannot communicate with 2005 corvette
    By radical243 in forum Gen IV V8 Specific
    Last Post: April 16th, 2011, 05:16 AM
  3. Replies: 7
    Last Post: November 1st, 2010, 08:24 PM
  4. 2005 Corvette PCM file
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: August 24th, 2005, 02:58 PM
  5. Will V7 work with 2005 Corvette?
    By Jim Shearer in forum General
    Last Post: February 22nd, 2005, 10:31 PM
