Results 1 to 5 of 5
Thread: Read ECM already flashed by other efilive.....
    Apr 2010
    Question Read ECM already flashed by other efilive.....
    I have a guy who bought a truck with efilive and a dsp5 switch on an lmm. he wants me to change some things and add some different tunes to his switch but it wont let me even read the tunes?
    Lifetime Member Gregs's Avatar
    Sep 2008
    I'm pretty sure you cant read dsp5 tunes out in which case you would have to get in touch with the previous tuner
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Oct 2004
    That's correct. A DSP5 tune on an LBZ/LMM is not able to be read. You'll either need the calibration file that you can modify. Or you need a stock file that you can upgrade to DSP5 yourself and then modify.
    Andrew
    EFILive Crew
    Apr 2010
    well that sucks, the truck isnt from anywhere close to where we live. theres no other way?
    Oct 2004
    Nope. No other way.
    Andrew
    EFILive Crew
  1. Flashed RR and ECM won't boot
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 4th, 2011, 08:53 AM
  2. Looking to unlock E38 ECM flashed with HP Tuners
    By 02Z06 in forum FlashScan V2
    Last Post: December 23rd, 2010, 01:32 AM
  3. can read but cant flash ecm
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: November 25th, 2008, 12:37 PM
  4. Cant read the ECM?
    By sweetdiesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 25th, 2008, 10:19 AM
  5. ECM read
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 23rd, 2006, 04:16 PM
