Thread: trans not going into 4th gear even though log says it is?
    Dec 2007
    Default trans not going into 4th gear even though log says it is?
    well i just figured out that my truck hasn't been going into 4th gear at all. It will do 3rd gear tcc locked but that's it. i hooked the scan tool up today and checked it. it says it is in 4th gear and the tcc is locked but if i manually shift it to 3rd the tcc unlocks then locks again and the rpms go back to what they were before.
    truck is a 2005 ccsb z71 sierra 5.3, 3.42, 32" tall tires. The only thing done to the truck is a built trans, trailblazer torque converter, and a k&n intake. I've only done trans tuning.. Could the tb stall be causing the truck to not go into 4th gear? I loaded the stock tune back in and it still wont go into 4th gear.
    here is the current tune on the truck.
    has no idea how to tune!!
    Dec 2007
    no one has anything that might help me out? im trying to figure out if its in the tune or if its the trans itself.
    Had this problem on my 02 TrailBlazer when I botched a shift kit and servo install. The PCM is commanding 4th lockup, however the trans isnt doing it. With your built trans, check the servo installation and if that doesnt do it, probably time for a rebuild...
    May 2011
    im trying to help him with this issue also. he is out of town for a few days and wanted me to ask if there is a setting or something in efi live to make it go into 4th? I see you can make it hold 4th thats all i can find. just to make sure its not a tuning issue.
    i talked to my trans guy he thinks the servo or accumulator piston maybe the issue also.
    any other imput would be great thanks
    Grab a laptop and your FlashScan, use the Scan tool, connect to the truck, then click F12 DVTs. Select LS1B PCM, then click activate. Go to the Auto Transmission, and then get to like 50-60mph where it should go into 4th. Click the checkbox, then click Hold 4th. If it shifts, then its a tune problem. If it doesnt, then its a mechanical problem.
    May 2011
    Amesome thanks for your help
    99 ECSB 1500 6.0 lq9/243 2wd 3.42 in the works.
    Efans - CAI - Walbro 255lph - Eaton LSD
    BTR STAGE 3 truck cam - 60lb Inj - MP122HH
    FLT Level 5 - 3000 SC YANK
    Pacesetter LT's - ORY
    13.170 @ 103.33 Mph -
  1. 4l80e 4th gear and tcc problem (running from 4L60E segment)
    By kkustomz in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 28th, 2011, 02:05 PM
  2. Need to hold 4th gear for dyno
    By samdweezel05 in forum Allison 5 & 6 Speed
    Last Post: July 1st, 2011, 01:54 PM
  3. Holding 4th gear for Dyno
    By Matt68 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 30th, 2011, 03:59 PM
  4. 4th gear goin rich all the time.
    By nathans1987 in forum Gen III V8 Specific
    Last Post: November 11th, 2009, 12:31 AM
  5. Keep TCC locked in 4th gear
    By FnGone in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 24th, 2008, 11:02 AM
