Results 1 to 8 of 8
Thread: Is there any way to run two DBW TBs on an E67 ECU?
    Sep 2010
    Default Is there any way to run two DBW TBs on an E67 ECU?
    Just as the topic states. V6 Application.
    I understand the MAF can be eliminated and tuned on speed density without a CEL (that is correct, right?)
    But I'd like to know if there is anyway to run two throttle bodies? I'm not sure how the wiring would work. It would essentially running twin stock TB's.
    Thoughts?
    Dec 2007
    Quote Originally Posted by E67boostquest View Post
    Thoughts?
    Google around. There is a few people doing this with different approaches.
    Sep 2010
    I have tried web searching. I've found nothing at relavent.
    Dec 2007
    This is one thread on another forum that google found. There are other posts there about dual TB setups. One mechanical another running the motor in parallel IIRC. Be interesting to know whether the slave suffers from drift.
    http://www.ls1.com.au/forum/archive/.../t-136493.html
    Sep 2010
    Wow thanks, not sure how I missed that. What were your search parameters?
    Dec 2007
    IIRC "dual throttle body LS1"
    Sep 2010
    Ahh, as I thought. I've come across this. It's just someone using the stock motor and sensor, and putting a couple of throttles side by side. Which might work out, but for this particular option, these throttle bodies will be about 3 feet apart...
    I'm looking for trying to run two separate units.
  1. What ECU will run a 6l80E?
    By nitrorocket in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: November 15th, 2011, 04:14 PM
  2. gmpp e67 ecu ls376/480
    By nutte in forum E37, E38 & E67 PFI ECM's
    Last Post: August 29th, 2011, 08:48 AM
  3. What do I do when I run out of fuel pump on my E67?
    By E67boostquest in forum E37, E38 & E67 PFI ECM's
    Last Post: February 2nd, 2011, 08:39 PM
  4. E67 After Run Fan Settings?
    By MattS in forum E37, E38 & E67 PFI ECM's
    Last Post: September 27th, 2010, 03:22 AM
  5. DBW Issue
    By sparkinak in forum Gen III V8 Specific
    Last Post: August 23rd, 2008, 01:45 PM
