Forgive me if I have missed this in another post or tutorial, i have been researching for the past few hours with no luck! ;-)
MAF tuning has been a dream with the E38 but smoothing out idle - and low rpm accell has been a bit more challenging. If I fail the MAF to SD, my idle/accell issues go away. MAF BEN's are +/- 2%.
Motor is a stock 4.8, LS3 MAF, LS2 intake, with LS6 cam. 80lb injectors could cause an issue I guess.
Can I run SD until a certain RPM or MAF frequency? I set my MAF fail LOW to 3000hz, it failed but would not re-enable above those frequency's and stuck with the VE values. I thought it is supposed to re-enable?
edit1_0008.tun
Thanks,
David
