Results 1 to 10 of 13
Thread: MAF wont fail for VVE tuning
    Member 2007chevy5.3l's Avatar
    Aug 2011
    Default MAF wont fail for VVE tuning
    Okay, followed the tutorial, unplugged the yellow wire and it wont run. Go ahead, make me feel stupid...
    What am I missing guys?
    07 Tahoe 5.3L, CAI/Longtubes
    Tahoe Speed Density VVEfilive.tun
    2007 5.3l Tahoe. K&N CAI, Pacesetter LT/ORY no muffler, vette servo, Tru-cool 40k, Innovate LC-1 wideband, 3.42's Circle D 3k, 100shot
    Slowly learning how to tune via EFILIVE
    Because you set the MAF DTC's to 'Not Reported', these need to still be enabled or the ECM won't switch to Speed Density mode because it never acknowledges the MAF has really failed and still attempts to run off a non existent MAF signal. By all means set the MIL to 'No MIL'.
    Your other option rather than unplugging the wire is to set the MAF Diagnostic test fail parameters so the MAF will always fail.
    So with the MAF still plugged in set as so:
    {C0301} MAF Frequency High Fail 150 Hz
    {C0302} MAF Frequency Low Fail 100 Hz
    {C0303} MAF Frequency High Failures 1
    {C0304} MAF Frequency High Passes 63
    {C0305} MAF Frequency Low Failures 1
    {C0306} MAF Frequency Low Passes 63
    {C0310} MAF Test Min Runtime 1.0 Seconds
    {C0311} MAF Test Min Voltage 8.0 V
    {C0312} MAF Test Min RPM 300 RPM
    What will happen here is the MAF will always produce a frequency over 150Hz with the engine running, so instantly the ECM will assume the MAF is faulty because of the value we put in {C0301} and so drop to SD mode.
    Aug 2011
    Okay so when I log the MAF Frequency Hz will it still show a reading or will it be 0? Thats how I checked to see if the MAF was failed or not
    Aug 2010
    If you setup your parameters for VVE tuning (disabled the MAF) per Swingtan's VVE Tutorial, or using the values Ross posted above, and you have a MAF DTC occurring (not a MIL light - this should also have been disabled - just the DTC itself set if you scan the ECM), then the ECM should have "Failed" the MAF. As long as the MAF is powered, and the signal wire is connected, it will continue to report data - but this will be ignored by the ECM.
    To completely eliminate MAF input to the ECM - remove the yellow wire from the MAF connector plug - and reconnect the plug to the MAF (this maintains IAT data).
    Removing the MAF signal wire (yellow) is also mentioned in Swingtan's tutorial.
    Regards,
    Taz
    Aug 2011
    Oh okay I think I get what you are saying. Im going to try the settings Ross suggests and see if that works. I will report back later tonight when I have given it a shot.
    Thanks Guys!
    Aug 2011
    Ross, thank you for getting me straight on the MAF fail parameters. I tried them out and they worked great.
    I did get a service traction control/stabilitrac light and I have the option of turing that off in B9901-B9902, after doin that it says "After applying this patch you must save the file, then perform a 'Full Flash' of the ECM". Does that mean I need to program the PCM with currently loaded operating system and calibration?
    Second, My trans shift firmer in 1->2 shift at part throttle, much too firm in my opinion. So, will I need to lower the 1->2 base pressure upshift to compensate?
    Lastly, What is an idea AFR, throttle and rpm for a "lean cruise"? I was seeing 15s-16s AFR at low cruise speeds and to me that seems a bit too lean. Any advice?
    Here is my log without the MAF. The VE map is pretty rough
    Tahoe NoMAF.efi
    Lifetime Member Gregs's Avatar
    Sep 2008
    Quote Originally Posted by 2007chevy5.3l View Post
    Tahoe NoMAF.efi
    1. yes
    2. I would NOT change the 1->2 base pressure. "Vehicles equipped with automatic transmissions should go to table {E0104} “Transmission DTC Fault Pressure Modifiers” and set P0101, P0102, and P0103 to NO to prevent the PCM from increasing shift pressures."
    3. lambda 1.05 or 15.4 if you are running non ethanol fuel, but as always this is a good starting point and you should adapt it for optimum resultsClick image for larger version.
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Aug 2011
    Quote Originally Posted by Gregs View Post
    1. yes
    2. Its been a while so i don't remember exactly but i think i remember disabling a trans code and i think there was a pressure adapt table for when there is a maf failure. Sorry its been a while. I would NOT change the 1->2 base pressure.
    Alright, I see how it likes 15.4 AFR. As of now its super lean. Im seeing 15.5-16.2 AFR at cruise. Definatly too lean but my VE is way out
    Sep 2008
    well its all just guesswork unless you have a dyno, for example on that graph it shows 12.6 afr as max power however the ideal afr is different for everyone so don't take the graph as the law.
    Stock for now
    Aug 2011
    Guess work it is! But I will be happy to have it atleast "close"
    Thank You for finding the Trans pressure tables.
  1. Need VVE tuning help
    By 2007chevy5.3l in forum Gen IV V8 Specific
    Last Post: August 25th, 2011, 01:39 PM
  2. Attempted a VVE and Disconnecting the MAF Killed the Engine
    By MN C5 in forum E37, E38 & E67 PFI ECM's
    Last Post: September 26th, 2009, 05:33 AM
  3. Tuning MAF vs VVE
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: August 27th, 2009, 01:29 PM
  4. Which maf fail numbers are you using for C2907 and C2908?
    By onfire in forum Custom Operating Systems
    Last Post: August 30th, 2007, 08:19 AM
  5. I cant get the"MAF freq Fail 1"parameter to = 0
    By SmaknSS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 2nd, 2005, 05:29 AM
