Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: Not getting maximum duration?
    Senior Member 2006Cummins's Avatar
    Sep 2011
    Default Not getting maximum duration?
    I have my max duration set to 3200us, and when logging the tune at wot I am only seeing 2800us. When using the highlighting tool while watching the log, it highlights 3200us. I don't see any limiters, or anything else, that could be causing max duration to come up short. Anyone care to take a look and see if you can give me a hand?
    Tune:
    409_T8_0012.ctd
    Data log:
    t8-10 5th wot.efi
    Mike
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    Jul 2011
    i dont know how to repost your file back up but i made a change to your main injection pulse. nothing big, but i think the issue was you were commanding between 2900-3200us between 150-160mpa and 2500-3200us between 120-140mm3. I by no means am a big time tuner, but i did stay at a holiday inn express last night...
    Nov 2010
    Did you disable the pulse limiter option??
    Didn't look at your tune...
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Jul 2011
    yeah, he disabled it
    Sep 2011
    Yes, thanks.
    So, did you just change 150-160mpa, and 120-140mm ranges, to 3200us?
    Can't argue with that then. lol
    Mike
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    Jul 2011
    kind of. are you trying to get 180mpa? i see in your sig that you have an aftermarket pump. if so, change the the 2466 and 2544 in the 120mm3 row to 3150 and 3175. leave the 3200 alone in the 140mm3 row. should do the trick. hope thats the issue.
    Sep 2011
    No. I was trying to stay under that.
    I'm making some progress. Looks like there are a couple of issues. I've got one more thing to try which I'm hoping will take care of it. I'll let you guys know.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    Junior Member chance cobb's Avatar
    Jun 2011
    did you get the bugs worked out ?
    Sep 2011
    Sorry it's been taking me a while to get back to this - It's been a little busy with the holidays. I set all of my limiters to efi's maximum. Now it actually reaches 145mm, which gave me another 100us. I think that it was the boost table that allowed this. Don't know why it goes to 145mm when my duration table only goes to 140mm, but that is another discussion I guess. I then lowered my pressure table to a maximum of 160mpa, which gave me an additional 200us. My actual rail pressure was a little higher than the desired, and was hitting the limiter which would pull fuel. Next I added duration to the 120mm range and have yet to data log. I am still about 200us under my commanded level, so I am curious to see what this last change will do. Thanks to everyone who has offered help - it is much appreciated. I will post more results soon.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    Senior Member DODGE74's Avatar
    Oct 2011
    Mike,
    are you running the latest candidate 7 software?
    Reason I ask is because when I switched over from the August software I was also having some issues with fuel limiters and a few other things.
    I went to the dealer, got a fresh flash and now all is perfect.
    06 QCLB, DRW
    Single pump
    Single turbo
    EFILive 772hp 1398tq
    gordon@innovativediesel.com
  1. duration/fuel pressure actual ?'s
    By olboyowl in forum Cummins 5.9L
    Last Post: October 14th, 2011, 02:36 AM
  2. Total duration looks long
    By AdamRRT in forum Cummins 5.9L
    Last Post: September 27th, 2011, 08:28 AM
  3. duration questioin
    Last Post: September 26th, 2011, 11:49 PM
  4. Fuel duration limiter troubles!
    By icem237 in forum Cummins 5.9L
    Last Post: September 26th, 2011, 05:45 AM
  5. Maximum VSS value?
    By jsttry in forum General
    Last Post: December 30th, 2006, 10:42 PM
