Results 1 to 3 of 3
Thread: help throttle acts like sticking
    Mar 2011
    Default help throttle acts like sticking
    In tune 5 which is base tune, this truck acts like the throttle is sticking when letting off, when this occurs i click it to tune 4 and it quits. Can some one look over the tune and let me know if they see anything? The truck has a stage 5 trans and bd low stall converter, it seems to occur after the first downshift after letting off
    Joe Kupferschmid
    Daves Diesel Angola
    www.angoladavesdiesel.com
    Diesel and gas tuning
    Personal Vehicles tunes with efi 06LBZ, 05lly, 2002 Z28, 2004 Gto
    Sep 2006
    I'm guessing B0742-0744 need some attention...Try starting with a stock TLIQ table, then make small adjustments...
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
    Dec 2005
    Quote Originally Posted by The Neens View Post
    I concur, also B0727 Row 0 - column 600 rpms
    www.mscservices.net
  1. E38 - Throttle Cut / Throttle Blip
    By Z06-GT3 in forum Lounge
    Last Post: June 14th, 2011, 04:16 AM
  2. Got Lc1 working but acts wierd now
    By pavetim in forum FlashScan V2
    Last Post: January 21st, 2011, 04:39 PM
  3. how to tune throttle follower and throttle cracker?
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 03:43 PM
  4. V2 acts up with the Serial connected
    By nonnieselman in forum FlashScan V2
    Last Post: November 18th, 2008, 02:25 PM
  5. Throttle VE
    By oztracktuning in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2008, 09:38 PM
