Results 1 to 5 of 5
Thread: OS3 installed
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Default OS3 installed
    I have done autoVE over the past few days and got it to a stage where i could upgrade my program to the new OS3 and setup all the other tables.
    It all worked fine. I now have a duel spark table, lean cruise enabled, PE at 95% and stoic to 75MAP then blending to similar to PE. I may as well turn PE off.
    I have even enabled IAT correction from data i collected while building the new VE table and i have it at about 1% correction every 10 deg.
    At the moment i have my desired spark table 3 deg above the lower one. I will trim them both together for a while keeping a 3 deg gap and then aim to pump up the hioctane table in cooler conditions.
    How do i set the amount of knock needed to learn either way with the spark tables. I would also like to plan how i can setup a table for ethanol fuel as well.
    Having some trouble with surging - have played a little with the timing correction of hi and low idle. But i think the issue is with idle air or something else.
    My VE table is not ideal near 400-800 i wish there was a 600 row as well !
    Great work Blacky and GMPX its a sweet and powerful package you have created.
    Jun 2005
    What size injectors are you running that you don't have ideal VE in the 400/800 rows?
    Are you constantly getting autoVE of like high 70's low 80's BEN?
    That is what I am seeing on the cars I have done with 60lb injectors.
    Nov 2005
    I just made the 400rpm and 800rpm cells much more similar hoping this may help some idle issues. I have 36lb injectors.
    Oct 2003
    Flyer - are these the 36 lb GTP (white) injectors?? If they are I have Injector Offset and Pulsewidth Tables from an ASA tune (58 psi fuel pressure) - if you want them.
    What are you tuning?? Mods??
    FWIW.
    joel
    Nov 2005
    They are the common SVO30 injectors. But thanks anyway.
    The car is a VX Clubsport 216 220 Cam 114LSA 1.8 rockers
    SS3600 Qtecs Ported TB (like a S3) 3.73 25% UDP
    Ported Heads at 10.7:1
    Its run 11.765/115 1.622 on MT ET street Radials.
    This was pre-heads.
  1. Can't get v2 installed on vista 64 bit
    By ThunderDan74 in forum FlashScan V2
    Last Post: February 26th, 2011, 04:42 PM
  2. LC-1's Installed
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: August 30th, 2007, 10:05 PM
  3. Need Help just installed my WB02
    By Spdfrk1990 in forum Gen III V8 Specific
    Last Post: June 16th, 2007, 01:00 PM
  4. LC-1 Installed
    By mcwarren in forum General
    Last Post: April 16th, 2006, 09:07 AM
