Page 12 of 12 FirstFirst ... 2101112
Results 111 to 119 of 119
Thread: Release Candidate 7, Dec 22, 2011
  1. #111
    Senior Member TexasCummins's Avatar
    Jul 2011
    I'm running into some ghosts with the newest release. I have also noticed at least one mis-labeled parameter. I datalogged a run and I will post some results in a bit.
    EFI Live - The Smarter way to tune!
    2006 Ram 2500 4x4
  2. #112
    Quote Originally Posted by MQ105 View Post
    Go to B4508 (or B4510) in the tune tool and find the link - the blue "B4507(9)" to click on to get to the axis table. It isn't there. All the other tables have links to the corresponding axis tables.
    Thanks, got that fixed for the next update.
  3. #113
    Jun 2011
    Thank you.
  4. #114
    Thanks for pointing it out, when you stare at those maps all day developing it's pretty easy to miss that sort of thing.
  5. #115
    Jul 2011
    {B4541} "Full Throttle Mode, TPS Enable" should be Disable since {B4540} is Enable.
    2006 Ram 2500 4x4
  6. #116
    Hi Nick,
    Found the fault and fixed it.
    Thanks for all the work you did tracking down and sending the trace files.
    The problem was the V8 software was not identifying the DSP5 tune files correctly when they were being opened and it was flashing part stock data and part DSP5 data - causing the problems you experienced.
    I expect to have an update (Release Candidate 8) available tonight or tomorrow.
    Quote Originally Posted by vortecfcar View Post
    I had a customer flash a .ctz file from this release into an LBZ truck and had some interesting things happen. The truck would only run on non-DSP, and would shut off immediately once the switch was switched to any DSP1-4. We tried a full reflash on the truck and then it wouldn't even click (no-start). The customer has the latest RC7 and both firmware/bootblock updates.
    Flashing the same tune in with V7.5 works fine. Truck runs as it should.
    Nick
  7. #117
  8. #118
    Yeah, I had to have a Bosch ECM on the bench again today
  9. #119
    I'm pretty sure you can't catch any communicable diseases from Bosch ECMs.
    But the rubber gloves and tongs was a bit too much.
  1. Release Candidate 2, Aug 19, 2011
    Last Post: September 13th, 2011, 09:58 AM
  2. Release Candidate 1, Aug 04, 2011
    Last Post: September 11th, 2011, 03:36 AM
  3. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
  4. February 26th 2011 release candidate 1
    Last Post: March 4th, 2011, 09:55 AM
  5. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
