Results 1 to 3 of 3
Thread: Commanded fuel limiter
    Member arinkuddy's Avatar
    May 2014
    Default Commanded fuel limiter
    I was wondering if anyone has figured out a way to get the commanded fuel above 160mm3. I want to push it up to around the EFILive limit of 250 but I seem to be hitting some hidden limiter. When logging it stops at 160mm3 exactly.
    And yes I realize the commanded fuel is basically arbitrary I am trying to limit the light switch effect when boost comes up.
    Nov 2010
    I think that's just the ecm limits, the CMC goes to 165, and I believe the cmd and cme go to 170.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    May 2014
    Thanks for the info.
    I ended up trying to use the 140-160 region to bring in the over stock fueling end that definitely helped. I had to do a lot of axis table changes.
    I thought about rescaling all the fuel axis by 1/2 or maybe even 1/10 but I'm a little concerned that might cause some unpredictable behavior.
    Sent from my SM-G935V using Tapatalk
  1. e67 commanded fuel going lean
    By b18cls1 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 2nd, 2015, 12:54 AM
  2. Commanded Fuel when Cranking
    By gpr in forum Gen III V8 Specific
    Last Post: March 11th, 2013, 11:33 AM
  3. Commanded fuel pressure Question
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: April 11th, 2012, 09:40 PM
  4. Commanded Fuel Pressure
    By Compcowboy in forum Cummins 6.7L
    Last Post: January 5th, 2012, 01:04 PM
  5. commanded air fuel
    By 69camaro5speed in forum General
    Last Post: March 11th, 2007, 12:37 PM
