Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: 48RE Parameters
    Senior Member TexasCummins's Avatar
    Jul 2011
    Default 48RE Parameters
    If I wanted to see governor pressure when in tow/haul mode, which table would I look at? There's normal (B4524), full throttle (B4526) and low range (B4522).
    EFI Live - The Smarter way to tune!
    2006 Ram 2500 4x4
    Nov 2009
    I recommend using the TTVA table, make very small changes. A couple *s can make a large difference.
    -Kory
    http://www.PPEI.com/
    Nov 2010
    Quote Originally Posted by TexasCummins View Post
    Normal...
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Jul 2011
    Another question I have is for the beta testers - have any of y'all tuned the transmission to drive and shift nicer with larger than stock tires?
    2006 Ram 2500 4x4
    Nov 2010
    As far as what?? Delayed shifts...firmness etc...
    Les Szmidt
    2007 5.9 Dodge Ram
    Nov 2009
    By far my friend...bump the shifts up with TTVA, lock/unlock control on the TC has really made the truck drive-able...That 3-4 shift with lockup at say 50mph with a 87% throttle kickdown are things of the past...the 48 is very very nice to drive now. Efilive has once again raised the bar on everything.
    -Kory
    Nov 2009
    my customers running large chargers have greatly benefited from being able to stay on top of them.
    -Kory
    Jul 2011
    Less TPS% for downshifts, firmness... with my 35's and 3.73's it lugs down horribly in fourth with the TCC locked between 50-65mph. For normal driving around town a little less pedal to downshift and get going would help.
    2006 Ram 2500 4x4
    Nov 2009
    The TPS for kickdown is in the parameters section i believe
    -Kory
    Jul 2011
    just when i thought the truck was at its limits, efilive goes and releases this...thanks to the efilive crew and beta testers for the early christmas gift. now if i can figure out what half of this stuff means. i'll have to watch what others are doing/recommending as this is not a strong point for me. thanks again to all involved.
  1. Idle Parameters
    By Highlander in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: November 22nd, 2009, 06:18 PM
  2. New A6 Parameters
    By gmh308 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: March 15th, 2009, 08:33 PM
  3. What parameters can a RR tune?
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 7th, 2008, 04:20 AM
  4. Any one know what parameters....
    By 98SS2836 in forum Gen III V8 Specific
    Last Post: January 16th, 2007, 05:01 AM
  5. outside parameters
    By wkdivr in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2005, 02:13 PM
