Results 11 to 20 of 28
Thread: 48RE Parameters
  1. #11
    Nov 2010
    Pay very close attention to output shaft speed for tuning...
    Lots of adjustability...just need to match stuff up correctly
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  2. #12
    Junior Member jordylee18's Avatar
    Oct 2011
    Would it be too much trouble for the EFILive professional tuners to make a transmission tuning tutorial?? Like what all should be changed if you have, say 200 hp more than stock??
  3. #13
    Jul 2011
    im sure there will be one out before to long. probably safe to say sometime early next year
  4. #14
    Nov 2010
    Trans tuning will NOT make your trans hold more power!!!
    Don't know if that is what your looking for, but needs to be said.
    Trans tuning addresses shift points and converter lock up and unlock conditions.
    Les Szmidt
    2007 5.9 Dodge Ram
  5. #15
    Jul 2011
    hope i dont get blasted for this, but the new update is great for yens with aftermarket transmissions, but can the trans tuning be of any benefit for the guys out there that are still stock? i know im pushing the limits with mine and if something happens, i will take full responsibility. just curious if there are some small changes that can be made to fix/better the 2-3 shuttle shifting and maybe a little firmer shift.
  6. #16
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    My understanding is the shuttle shifting has to by addressed physically...yes the software is sweeetttt for the stock trans
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
  7. #17
    Jul 2011
    good deal, thanks kory. i have the new borg warner gov press solenoid sittin in the garage. gotta make some time to put it in.
  8. #18
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    Okay, I will say this with the trans tuning....
    GO SLOW!
    Small changes can make HUGE impacts, especially with the governor pressure.
    Also, remember, most of the parameters are based off of output shaft speed and throttle percentage, so knowing the output shaft speed you're playing with is important.
    I attached a very basic calculator to use for output shaft speed. It's not dead on perfect, but it gets you close. All you need to enter is RPM, gear ratio and tire size and it will calculate the shaft speed, etimated vehcicle speed and tire rev's per mile.
    1207 HP / 1612 TQ
  9. #19
    Dec 2009
    Quote Originally Posted by jordylee18 View Post
    Transmission tutorial for 200 hp over stock.
    Step 1 - Call Transmission builder of choice
    Step 2 - Open Wallet
    Step 3 - Drop Pants
    Step 4 - Pay Though The Azz
    Tutorial Complete.
    1207 HP / 1612 TQ
  10. #20
    Dec 2009
    Also, those of you with stock valve bodies WILL NOT get the torque converter to lock in 2nd gear, the fluid flow channel doesn't exist.
    1207 HP / 1612 TQ
  1. Idle Parameters
    By Highlander in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: November 22nd, 2009, 06:18 PM
  2. New A6 Parameters
    By gmh308 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: March 15th, 2009, 08:33 PM
  3. What parameters can a RR tune?
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 7th, 2008, 04:20 AM
  4. Any one know what parameters....
    By 98SS2836 in forum Gen III V8 Specific
    Last Post: January 16th, 2007, 05:01 AM
  5. outside parameters
    By wkdivr in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2005, 02:13 PM
