Results 1 to 3 of 3
Thread: 120 mm3
    Jun 2009
    Default 120 mm3
    120 mm3 = WOT, right?
    In my limited logging experience I’ve found on WOT runs that very few 120mm3 cells get populated in the various tables I’ve built. In this context very few = a couple.
    Is this normal?
    Mar 2009
    The ECM has the ability to go to 120MM3 of fuel, btu that does not mean it will always command it. In stock form I don't think they ever get much beyond about 105MM3 of fuel from what I seen in the tuning. Sort of like an LB7, they go up to 100MM3 of fuel but don't go beyond 89MM3 of fuel with stock limiters.
    Jun 2009
    I figure it's probably normal and the truck runs awesome. Just wanted to see what others have noticed on LMMs.
  1. MM3 vs. PW?
    By mstordahl in forum Cummins 5.9L
    Last Post: October 26th, 2011, 12:23 AM
  2. Auto VE = 120%
    By L31Sleeper in forum General (Petrol, Gas, Ethanol)
    Last Post: January 21st, 2010, 04:29 AM
  3. replace the suspension then no more than 120 KMH
    By odd boy in forum Gen III V8 Specific
    Last Post: March 6th, 2009, 08:40 AM
  4. 120 to 12v converter
    By sparkwirez06 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2006, 09:16 AM
