Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Transmission Tuning
  1. #21
    Jan 2012
    sometimes the answer is so obvious, you talk yourself out of it. :-) Thanks!
  2. #22
    Junior Member chance cobb's Avatar
    Jun 2011
    any new updates i am about to start playing around with my trans soon. any help would be appreciated on where to start first thanks
  3. #23
    Lifetime Member FUBAR's Avatar
    Feb 2011
    TTVA by small increments. And some of the parameters such as full throttle shift, kickdown, etc.
    06 LBZ, EFILive
  4. #24
    Nov 2010
    As FUBAR said...TTVA and kickdown, full throttle etc.
    Most of the rest seem to be valvebody dependant. Try to change something and test to see if it works as desired.
    Small change..test...small change...test...circle of life.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  5. #25
    Jun 2011
    thanks guys
  6. #26
    Senior Member TexasCummins's Avatar
    Jul 2011
    I made some small changes to the TTVA degrees table and it completely changed the way the truck accelerates. I noticed less smoke off the line during normal stop-and-go situations too. I will continue to tweak it and see if I can get back out to the track soon.
    EFI Live - The Smarter way to tune!
    2006 Ram 2500 4x4
  7. #27
    Junior Member noff's Avatar
    Mar 2012
    I was having problems with the flare shifting 3rd and gear hunting 1-2-1. tried few different things trying to fix it, only one tp really help was i rasied my normal gov pressure up 10% , also it spreaded out shift points.
    Black06MegaCab/DTT/TDC/EFI LIVE/Gauges/Raptor150/HTTss62-71/AFEPusher/5''ss/TGC8inLongArm/Fox/38''MG ..... RED / 2005 / QCSB / G56 / SBDD / TST / Smarty TNT / ETC... K.I.A.
  8. #28
    Aug 2012
    The shift from 3rd to4th always seems to hold on when driving in town, light throttle. If I get off the skinny peddle just a bit it will shift or get on it a little more but if I stay constant it just seems to hold for 3-4 sec and then shifts. Any ideas
  9. #29
    Aug 2012
    Sorry, I should have also added I have tried increasing govern pressure by 5% across the board, Kickdown and I adjusted TTVA in the 5% range from 3 to 5. Now one thing I was thinking is maybe there is too much govern pressure in that area?
  1. How about a transmission tuning tutorial!
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 3rd, 2020, 04:53 AM
  2. Any news on transmission tuning?
    By 68showngo in forum Cummins 5.9L
    Last Post: September 12th, 2011, 08:42 AM
  3. LMM transmission tuning question??
    By jakebrake4x4 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 7th, 2011, 10:55 AM
  4. Supercharged without automatic transmission tuning.
    By scdyne in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 16th, 2010, 10:06 AM
  5. Transmission Info
    By Dave Lewis in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 17th, 2005, 03:55 PM
